ɹəuəllıʍ ʇɐb Posted August 17, 2009 Author Report Share Posted August 17, 2009 Autoruns for Windows 9.53 at Sysinternals.Question: does anybody beside me actually use Autoruns? If not, I will stop posting update notices here. Thank you. Quote Link to comment Share on other sites More sharing options...
AlanHo Posted August 17, 2009 Report Share Posted August 17, 2009 I don't use it. Quote Link to comment Share on other sites More sharing options...
andsome Posted August 17, 2009 Report Share Posted August 17, 2009 Autoruns for Windows 9.53 at Sysinternals.Question: does anybody beside me actually use Autoruns? If not, I will stop posting update notices here. Thank you.NO. Quote Link to comment Share on other sites More sharing options...
D4\/!d Posted August 17, 2009 Report Share Posted August 17, 2009 Nope - cannot understand it. Quote Link to comment Share on other sites More sharing options...
Boris Posted August 17, 2009 Report Share Posted August 17, 2009 Nope - cannot understand it. I can :D ....................... ( and use it !) Quote Link to comment Share on other sites More sharing options...
Sbrideau Posted October 27, 2009 Report Share Posted October 27, 2009 I just saw this topic, Autoruns seems like a neat program, I might try it in the near future. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted October 2, 2010 Author Report Share Posted October 2, 2010 Autoruns for Windows 10.03 at Sysinternals.This update adds a number of additional shell extension locations and reports Safe Mode’s alternateshell value. Quote Link to comment Share on other sites More sharing options...
bludgard Posted October 2, 2010 Report Share Posted October 2, 2010 Question: does anybody beside me actually use Autoruns? If not, I will stop posting update notices here. Thank you.I use Autostart program viewer from Sysinterals.I am just realizing that these two programs appear much alike.Nevertheless,please keep us updated,it is much easier than browsing for updates for ourselves.:lol: Thanks,Pat. EDIT:After a little searching on my own,I found that Autostart and Autoruns are in fact the same.I shall update forthwith. Quote Link to comment Share on other sites More sharing options...
bludgard Posted October 2, 2010 Report Share Posted October 2, 2010 Question: does anybody beside me actually use Autoruns? If not, I will stop posting update notices here. Thank you.I use Autostart program viewer from Sysinterals.I am just realizing that these two programs appear much alike.Nevertheless,please keep us updated,it is much easier than browsing for updates for ourselves.:lol: Thanks,Pat. EDIT:After a little searching on my own,I found that Autostart and Autoruns are in fact the same.I shall update forthwith.Any Idea why there are two apps in the .zip?They seem to be identical other than the size of the file.Is one app x64? Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted October 10, 2010 Author Report Share Posted October 10, 2010 Autoruns for Windows 10.04 at Sysinternals.This fixes a toolbar drawing bug that shows on Windows XP. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted October 10, 2010 Author Report Share Posted October 10, 2010 Any Idea why there are two apps in the .zip?They seem to be identical other than the size of the file.Is one app x64? The package contains Autoruns and Autorunsc; the latter being the command line version, which can write output in CSV format (comma-separated text file). Quote Link to comment Share on other sites More sharing options...
bludgard Posted October 10, 2010 Report Share Posted October 10, 2010 Any Idea why there are two apps in the .zip?They seem to be identical other than the size of the file.Is one app x64? The package contains Autoruns and Autorunsc; the latter being the command line version, which can write output in CSV format (comma-separated text file).Thank you for the clarification,pat.I tried to find any relevant information on the subject but failed. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted November 30, 2010 Author Report Share Posted November 30, 2010 Autoruns v10.06This release fixes a bug that could affect delete and disable operations on entries stored as multisz registry values.Download: http://technet.microsoft.com/en-us/sysinternals/bb963902.aspx Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted April 14, 2011 Author Report Share Posted April 14, 2011 Autoruns v10.07This release fixes a bug in the Process Explorer integration on 64-bit Windows and properly escapes XML characters in Autorunsc.exe output.Download: http://technet.microsoft.com/en-us/sysinternals/bb963902.aspx Quote Link to comment Share on other sites More sharing options...
