Help! Mouse going berserk!
robj
Logitech MX 700 optical mouse
Just started happening - when mouse is stationary the "pointer icon" starts to wander down the screen. It takes about 10 secs to get from top to bottom. Clearly it is difficult to position accurately.
Any suggestions please? I have cleaned the contacts and the battery level is good.
I always use a sheet of white paper as a mouse mat. It doubles up as a scribbling/doodle/note pad.
Ensure the mouse rests on a level surface.
If this is severe, check your system for anything called "Crazy Mouse". This is a piece of so-called joke software that causes the mouse to behave erratically but it is usually more pronounced than what you are experiencing.
