acidcool Posted January 29, 2007 Report Share Posted January 29, 2007 How can i put back the audio sound of my computer because my dad disable it. I can't listen to music. :( :( Anyone pls help me.thanks.. Quote Link to comment Share on other sites More sharing options...
rong Posted January 29, 2007 Report Share Posted January 29, 2007 On the right hand side of the task bar click on the volume icon and untick the mute. Quote Link to comment Share on other sites More sharing options...
Irene Posted January 29, 2007 Report Share Posted January 29, 2007 How can i put back the audio sound of my computer because my dad disable it. I can't listen to music. :( :( Anyone pls help me.thanks..Your Dad would probably send a lynching party for us!! Maybe if you promised to keep the sound low he would put it back on again. Perhaps you could wear headphones? ;) Quote Link to comment Share on other sites More sharing options...
Coreper Posted January 29, 2007 Report Share Posted January 29, 2007 do you have audio drivers installed?you can see this by doing: Control Panel > System > Hardware > Device Manager, then check if there are objects with a ? in front of them [these arent [or not properly] installed. Another way to check this is by go to the device manager and goto: Sound, video and game controllers and check if all devices work properly Quote Link to comment Share on other sites More sharing options...
andsome Posted January 30, 2007 Report Share Posted January 30, 2007 You said that your dad disabled the sound, so it was obviously working before. Did he perhaps do this for a good reason? Were you driving the house mad with noise. Maybe if you promise to keep the volume down, he would re-enable it. I wish I could have disabled my sons Hi fi when he was younger and lived at home. Quote Link to comment Share on other sites More sharing options...
acidcool Posted January 30, 2007 Author Report Share Posted January 30, 2007 Yeah i do that but I can't still fix it.It happened when my dad reinstall XP, since then there's no sound in my computer even if I enter a chat room the sound is off. Can I do something with that?Thanks to you guys for your answers. Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted January 30, 2007 Report Share Posted January 30, 2007 Perhaps your drivers have not been installed yet.Check the website of your hardware manufacturer too see if there is an updated driver available. Quote Link to comment Share on other sites More sharing options...
cozofdeath Posted January 31, 2007 Report Share Posted January 31, 2007 If I was the parent I would have disabled the audio service. Click the Start button, run, type services.msc and make sure Windows Audio is Started. If this is not the case check the device manager for driver problems, then the Sounds and Audio devices in the control panel along with any other audio applets in there. There is a mute setting in there also and other things that must be set for the sound to work. Just some other things to try, hope it helps. Quote Link to comment Share on other sites More sharing options...
acidcool Posted February 5, 2007 Author Report Share Posted February 5, 2007 If I was the parent I would have disabled the audio service. Click the Start button, run, type services.msc and make sure Windows Audio is Started. If this is not the case check the device manager for driver problems, then the Sounds and Audio devices in the control panel along with any other audio applets in there. There is a mute setting in there also and other things that must be set for the sound to work. Just some other things to try, hope it helps.What kind of driver im going to install and what is the common driver to fix the sound of my computer? And Where can I download that? Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted February 6, 2007 Report Share Posted February 6, 2007 Open the Device Manager and check if you have any yellow exclamation marks; especially on 'Sound, video and game controllers'.If so, tell us the exact device name that has the exclamation mark. Quote Link to comment Share on other sites More sharing options...
acidcool Posted February 6, 2007 Author Report Share Posted February 6, 2007 Open the Device Manager and check if you have any yellow exclamation marks; especially on 'Sound, video and game controllers'.If so, tell us the exact device name that has the exclamation mark.Yeah it has a yellow, but not Exclamation mark it's Question mark on Multimedia Audio Controller on the device manager..What kind of driver I should download and where?. thanxs Quote Link to comment Share on other sites More sharing options...
nellie2 Posted February 6, 2007 Report Share Posted February 6, 2007 Do you have a seperate sound card? If not, what motherboard do you have? Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted February 7, 2007 Report Share Posted February 7, 2007 Unfortunately "Multimedia Audio Controller" does not give enough information to lead to a specific device driver.Please try to find the answer to Nellie's question above. Also, in the Device Manger, try Properties on the device with the yellow question/exclamation mark, and find out what the exact error is.You can also try to download System Information for Windows, run it, and see if it gives you more information than the Device Manager. Quote Link to comment Share on other sites More sharing options...
cozofdeath Posted February 7, 2007 Report Share Posted February 7, 2007 Try this ...http://support.microsoft.com/kb/142731When you right click on Media Control Devices and select properties then click the properties tab do you have anything listed under Media Control Devices? Quote Link to comment Share on other sites More sharing options...
