CPU Temperature
I just downloaded the latest version of 'Speccy'.
It shows that my CPU is running at the following temperature....
Do you think that average 40deg is OK? :unsure:
Run Speccy under load e.g. at the same time as doing both a full Anti-irus Scan and a Malware-Bytes Anti-malware scan and see what the temperature is like then :)
Hi,Irene.
Specs for your Wolfdale CPU is here:--->;http://www.cpu-world.com/CPUs/Pentium_Dual-Core/Intel-Pentium%20Dual-Core%20E6300%20AT80571PH0722ML%20(BX80571E6300).html
(Please copy and paste above,as something is wrong with my inserting link abilities) :(
Tcase shows 74+ as max rated temp.However,I've heard of 100 or more when overclocking as stable.
Clock speed rated at 1.06-3.33MHz.
You certainly are in the safe zone. :)
I agree that 80 deg is high and when I first built the machine I tried desperately to get it lower. Nothing I did would get the temp down without some totally impractical measures being taken but, after a time, I noted that the machine ran perfectly OK so I left it alone. It's in daily use for about 12 - 14 hours
That computer is about eight years old now and apart from a replacement PSU and a few noisy fans, it is the same essential hardware as it was when I built it. It's now running W7 without any problems.
