Slate Blackcurrant Watermelon Strawberry Orange Banana Apple Emerald Chocolate Marble
Lamb Chop
M$ wireless mouse 3000
I'm having a problem i cant seem to fix - the mouse curser is wobbling cant get it to stay on where point etc. Does it a lot - looked for reason cant find.
I also have a 3000 wired via USB keyboard which my W7 on Devices shows HID Keyboard device, HID Compliant mouse and M$ wireless transceiver - 3 items - is this correct or part of problem I wondered always shown it like this.
Not sure if this makes for a problem as I think Windows may see it as pair maybe as you can get combo of mouse with keyboard 3000 also.
 Also a couple of times found M$ had installed on updates the Mouse and keyboard center, And got rid of it and for a while all was well but again started wobbling unable to get it to stay first off etc annoying trying to click and then found again had got the mouse keyboard center and again uninstalled.
And still this "cant point and click"  without having to get it to stay long enough now and then  continues - thought had fixed it as stable for a while after last uninstall of keyboard center.
And is stable on here - but just was working and it drove me insane. Maybe its certain sites?
ie point at bar above say font and it shows up as a hand and 100% still.
[Hope this makes sense!  If not forgive on pain meds waiting for hip knee replacement and still got to wait til Sept 23 when private health insurance kicks in as wait for public 2-4 years on private 1 year nearly there. My bad thought covered as pay levy on income tax but seems not so.Hubbie says I am not always clear these days on things I explain - Senior moments too ]
Any ideas?
Share this post
Link to post
I would suggest having a look inside the Mouse. They are usually very easy to open up, given a suitable little screwdriver. Dust can collect in there and cause problems, but it takes a while to do so.
Share this post
Link to post
The quickest way to determine whether it is the mouse at fault or the computer is to buy or borrow another mouse and keyboard and see whether the cursor wobble continues.
If you are using an old fashioned mouse with friction wheels inside - then dust can be a problem. If however - as is more likely - the mouse is a laser one - dust is not likely to be the problem
Share this post
Link to post
Not sure re magnetic etc its this one https://www.microsoft.com/accessories/en-us/products/mice/wireless-mobile-mouse-3000/2ef-00013
Its settled down for a while again now. Could be batteries as they are going very quickly when once lasted so long forgot they were there. New box. Duracell exp 2022 - could be duds ? Last one lasted around 1 month I dont turn it off at all. Never have.
Share this post
Link to post
I've had a squizz, and cant see anywhere to use a screw driver.
See answer also to Alan Ho.
Thanks anyway.
Share this post
Link to post
The usual place on all that I have had is underneath at the back end (the end that points away from the screen) Sometimes there is a little paper/plastic/foil disc, of about 7mm, covering it.
Share this post
Link to post
Not on my mouse and hubbies exact same. Others old ones - will look
Reminds me I have a cupboard full of bits of computers over years - including mice and keyboards.
:Thanx2:
Share this post
Link to post
As the original post is nearly two years old I suspect that Lamb Chop has fixed her mouse issues. As to ball mice being easier to open, true but I for one don't miss the regularly having to scrape yuck and fluff off the rollers. Optical suits me fine.
Share this post
Link to post
Bela - why not climb into the 21st century and get your self a laser mouse. No cleaning at all then.
Share this post
Link to post
I don't need to clean the LED in my existing mouse and have a tendency to use Poundland mice on the grounds they're almost as cheap as I am and more reliable. When they change over to laser so will I.
Share this post
Link to post
Realized over time that it is the batteries fading that cause the wobble for some reason.
BTW dont bother to pay extra for the Blue ones Duracell put out they dont last any longer IMHO.
Share this post
Link to post
I buy Duracell Industrial-grade batteries. They are cheaper than the retail packs but probably of the same construction - you're just not paying out for silly battery checkers (which are pretty much useless) and fancy packaging.
Share this post
Link to post
Used to buy shed loads of those at Kays, right up to the point I negotiated a better deal from Varta.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
