Guest ellas Posted October 23, 2003 Report Share Posted October 23, 2003 things to look at nel Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted October 23, 2003 Report Share Posted October 23, 2003 and Quote Link to comment Share on other sites More sharing options...
Guest nellie2 Posted October 23, 2003 Report Share Posted October 23, 2003 Like I said I didn't think you had the msconfig option in xp but it is ok because I have system mechanic that lets me edit my start up folder, which I just have.... shall I reboot then and see what happens????? Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted October 23, 2003 Report Share Posted October 23, 2003 also Quote Link to comment Share on other sites More sharing options...
Chris Posted October 23, 2003 Report Share Posted October 23, 2003 Only use Windows controls, as for all you know (although i doubt it) SM maybe the cause. Quote Link to comment Share on other sites More sharing options...
Guest nellie2 Posted October 23, 2003 Report Share Posted October 23, 2003 oh msconfig does work.... well you learn something new every day... Im gonna take the bull by the horns and reboot then.... see what happens. Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted October 23, 2003 Report Share Posted October 23, 2003 you said disc repair nel,do you mean recovery console. Quote Link to comment Share on other sites More sharing options...
Guest nellie2 Posted October 23, 2003 Report Share Posted October 23, 2003 no Ellas, I right clicked on my c drive in my computer and set the comp to repair errors on the disk at next boot up in the properties option.As you can see I am here anyway which is further than I got earlier. I was still a bit sticky at start up but at least I am not frozen out any more. Thank you.... wonder what caused all that then? :huh: Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted October 23, 2003 Report Share Posted October 23, 2003 anymore probs stick the disc in and run the recovery console. Quote Link to comment Share on other sites More sharing options...
Guest nellie2 Posted October 23, 2003 Report Share Posted October 23, 2003 I had a look at recovery console once before and I am afraid I got a bit lost :( Is there a manual anywhere do you know?? Quote Link to comment Share on other sites More sharing options...
Guest Grim Reaper Posted October 23, 2003 Report Share Posted October 23, 2003 one has to admit that one has tried the recovery console and was slightly miffed too....you got lost nell...i don't believe it! Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted October 23, 2003 Report Share Posted October 23, 2003 see that thing called help and support on the start menu :D Quote Link to comment Share on other sites More sharing options...
Guest nellie2 Posted October 23, 2003 Report Share Posted October 23, 2003 you got lost nell...i don't believe it!Yup...... funnily enough I don't have any directions in words of one syllable for the recovery console!!!!! :D :D :D Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted October 23, 2003 Report Share Posted October 23, 2003 well it there if you look properly Quote Link to comment Share on other sites More sharing options...
Guest Grim Reaper Posted October 23, 2003 Report Share Posted October 23, 2003 would they have made a difference then? Quote Link to comment Share on other sites More sharing options...
Guest nellie2 Posted October 23, 2003 Report Share Posted October 23, 2003 Yes I am reading all about it now.... but you need to know the commands don't you. I shall have to print them off I think. Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted October 23, 2003 Report Share Posted October 23, 2003 no just put the cd in and press R Quote Link to comment Share on other sites More sharing options...
Guest nellie2 Posted October 23, 2003 Report Share Posted October 23, 2003 ok.... will try that next time!!! Quote Link to comment Share on other sites More sharing options...
Guest nellie2 Posted October 23, 2003 Report Share Posted October 23, 2003 Oh big Grrrrr........... it's doing it again. Gonna shut down soon and do the recovery thing or repair with the xp disk. I don't mind so much now because we have the hot fix download thing which is only 9mb instead of nearly 50mbs :) Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted October 23, 2003 Report Share Posted October 23, 2003 funny I nearly replied that will be 5 minutes then :D Quote Link to comment Share on other sites More sharing options...
mark2 Posted October 23, 2003 Report Share Posted October 23, 2003 Sorry Nellie had to go out. :( Info on ctfmon here can be a bit of a resource hog occasionally.Glad you found msconfig :D NeroCheck = C:\WINDOWS\System32\NeroCheck.exe is something relating to Incd I believe, altho I have Nero I never use Incd as it has caused probs for some XP users.The followingNvCplDaemon = RUNDLL32.EXE C:\WINDOWS\System32\NvCpl.dll,NvStartupnwiz = nwiz.exe /install you can launch from programs when requiredQuickTime Task = "C:\Program Files\QuickTime\qttask.exe" -atboottime I got rid of completely from my system, didn't like quick time. Quote Link to comment Share on other sites More sharing options...
mark2 Posted October 23, 2003 Report Share Posted October 23, 2003 duplicated postabove post seemed to have disappeared, forum glitch strikes again :D Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted October 23, 2003 Report Share Posted October 23, 2003 I think nels probs are deeper than a few startup programs running. Quote Link to comment Share on other sites More sharing options...
mark2 Posted October 23, 2003 Report Share Posted October 23, 2003 Agree, if software not causing it can only be H/ware or drivers. :( Quote Link to comment Share on other sites More sharing options...
monkeyhanger Posted October 23, 2003 Report Share Posted October 23, 2003 I think nels probs are deeper than a few startup programs running.Not having a lot of luck with x\p nell. :( I agree with ellas andNeroCheck = C:\WINDOWS\System32\NeroCheck.exe is something relating to Incd I believe, altho I have Nero I never use Incd as it has caused probs for some XP users. does cause probs on some machines.Every thing in msconfig \ startup can be turned off and the machine rebooted without any adverse results. ( except virus checking if conecting to the net.) Quote Link to comment Share on other sites More sharing options...
