monkeyhanger Posted October 23, 2003 Report Share Posted October 23, 2003 Also worth doing is to turn off automatic restarts to get a bsod with the data. Sorry if you have done this or did youonly get it through event viewer. Quote Link to comment Share on other sites More sharing options...
Guest nellie2 Posted October 23, 2003 Report Share Posted October 23, 2003 I am still having the problem, did a repair and that hasn't worked..... took avast av off because that was the first thing I put on and I thought that might be causing probs.... so am surfing unprotected at the moment. :(It is definitley something to do with those two error messages that I posted earlier because they keep coming up. I am tempted to reformat.... seriously.... because nothing seems to be working!!! :(... in safe mode again right now Quote Link to comment Share on other sites More sharing options...
monkeyhanger Posted October 23, 2003 Report Share Posted October 23, 2003 I would also recommend looking at device manager, if you have not already, for conflicts.It's not much nell, but it may point something out. Quote Link to comment Share on other sites More sharing options...
monkeyhanger Posted October 23, 2003 Report Share Posted October 23, 2003 Try. Go to msconfig, in safe mode, startup and disable all. Reboot. This will tell you if one of the startup progs is a problem.Also in msconfig \ services. Tick the box for hide all microsoft services. What is left? Quote Link to comment Share on other sites More sharing options...
mark2 Posted October 23, 2003 Report Share Posted October 23, 2003 I'm running Avast on 2 systems no probs at all Nellie. Quote Link to comment Share on other sites More sharing options...
Guest nellie2 Posted October 23, 2003 Report Share Posted October 23, 2003 here is a pic of whats left in services.... are you saying disable EVERYTHING in startup????? Quote Link to comment Share on other sites More sharing options...
mark2 Posted October 23, 2003 Report Share Posted October 23, 2003 The ones in the startup tab nellie, next tab to the right Quote Link to comment Share on other sites More sharing options...
monkeyhanger Posted October 23, 2003 Report Share Posted October 23, 2003 here is a pic of whats left in services.... are you saying disable EVERYTHING in startup?????Yes. Do not be afraid sweet fairy :wub: Look at my post at 9.48. the jpeg Quote Link to comment Share on other sites More sharing options...
Guest nellie2 Posted October 23, 2003 Report Share Posted October 23, 2003 ok well here is the start up one... I have taken out the ones we already talked about, are you saying untick ALL the others???? Quote Link to comment Share on other sites More sharing options...
mark2 Posted October 23, 2003 Report Share Posted October 23, 2003 It is safe to do that Nellie Quote Link to comment Share on other sites More sharing options...
Guest nellie2 Posted October 23, 2003 Report Share Posted October 23, 2003 ok.... will do and will reboot. No conflicts in device manager by the way Quote Link to comment Share on other sites More sharing options...
monkeyhanger Posted October 23, 2003 Report Share Posted October 23, 2003 Yes. :) Quote Link to comment Share on other sites More sharing options...
monkeyhanger Posted October 23, 2003 Report Share Posted October 23, 2003 Seems strange that that rundll is in the startup tab. Anyone else have that? :huh: Quote Link to comment Share on other sites More sharing options...
mark2 Posted October 23, 2003 Report Share Posted October 23, 2003 Something to do with the sound/audio it appears Cmaudio = RunDll32 cmicnfg.cpl,CMICtrlWnd Quote Link to comment Share on other sites More sharing options...
monkeyhanger Posted October 23, 2003 Report Share Posted October 23, 2003 Ah. Thanks Mark.If it gets much more tech than this, then I'll be about knackered. :unsure: Quote Link to comment Share on other sites More sharing options...
mark2 Posted October 23, 2003 Report Share Posted October 23, 2003 Google throws up 2 pages with references to it but it doesn't appear to be a nasty. :) Quote Link to comment Share on other sites More sharing options...
Guest nellie2 Posted October 23, 2003 Report Share Posted October 23, 2003 Im back but things still seem a bit sticky.... Quote Link to comment Share on other sites More sharing options...
doug Posted October 23, 2003 Report Share Posted October 23, 2003 Crossed fingers here. Please be my trail blazer. :) Quote Link to comment Share on other sites More sharing options...
mark2 Posted October 23, 2003 Report Share Posted October 23, 2003 Running sort of normal ?, not in safe mode ?How many processes does task manager show now ? Quote Link to comment Share on other sites More sharing options...
Guest nellie2 Posted October 23, 2003 Report Share Posted October 23, 2003 back in safe mode cos the effin thing froze up again...... getting really fed up with this now.I think I will just trash everything and start again Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted October 23, 2003 Report Share Posted October 23, 2003 nel take that ram out and see what happens. Quote Link to comment Share on other sites More sharing options...
Guest nellie2 Posted October 23, 2003 Report Share Posted October 23, 2003 I was having slow down and sticky problems before I put the ram in to be honest Ellas.... it seemed to clear up and then all of a sudden started up tonight. Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted October 23, 2003 Report Share Posted October 23, 2003 when then,what old hardware are you using Quote Link to comment Share on other sites More sharing options...
Guest nellie2 Posted October 23, 2003 Report Share Posted October 23, 2003 CD rom, dvd, floppy, graphics card, hdds Quote Link to comment Share on other sites More sharing options...
mark2 Posted October 23, 2003 Report Share Posted October 23, 2003 Back to basics Nell, add one bit at a time ? Quote Link to comment Share on other sites More sharing options...
