Chris Posted September 12, 2004 Report Share Posted September 12, 2004 When I wizz of a label in Nero it prints it to a CD shaped sticky piece of paper.I then peel back the sticky bit and place it on this plastic thing, i lower the CD onto a plate and push down. The CD sticks to the paper and hey presto I have my label on my CD.Not very technological and primitive one would say. But it works...BUT...what do use to get the sicky bit onto the CD?Or do you have a fancy CD drive that can burn the label on the disk. Quote Link to comment Share on other sites More sharing options...
r4may Posted September 12, 2004 Report Share Posted September 12, 2004 I then peel back the sticky bit and place it on this plastic thing, i lower the CD onto a plate and push down. The CD sticks to the paper and hey presto I have my label on my CD.Not very technological and primitive one would say.I print a CD Label and use a spring loaded Plastic gizzmo from 'Pressit' to apply the label to the CD.Again quite a primitive method but is works well Quote Link to comment Share on other sites More sharing options...
trackrat Posted September 12, 2004 Report Share Posted September 12, 2004 As above Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 12, 2004 Report Share Posted September 12, 2004 I've been using printable discs and an Epson R200/300 for some months now. A quick lacquer spray and they look very good.Discs for my own use have the handwritten black marker pen finish. Quote Link to comment Share on other sites More sharing options...
nellie2 Posted September 12, 2004 Report Share Posted September 12, 2004 My printer has a doo dah that will print straight to your CD but I've never used it. I normally just write on mine with a CD pen because my CD's are usually just backups.If I want to make a label then I have one of those plastic things that you have. Quote Link to comment Share on other sites More sharing options...
Chris Posted September 12, 2004 Author Report Share Posted September 12, 2004 What printer? Quote Link to comment Share on other sites More sharing options...
D4\/!d Posted September 12, 2004 Report Share Posted September 12, 2004 I use a felt tip pen - how else do you do it? :confused: Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 12, 2004 Report Share Posted September 12, 2004 What printer?Who are you asking?I've used an Epson R200 and an Epson R300 Quote Link to comment Share on other sites More sharing options...
Chris Posted September 12, 2004 Author Report Share Posted September 12, 2004 errr nel. Quote Link to comment Share on other sites More sharing options...
AlanHo Posted September 12, 2004 Report Share Posted September 12, 2004 I write on mine with a CD marker pen.I read in a trade mag that it is not recommended to use stick-on labels on CD's for two reasons.It can introduce out of balance causing disc wobble in high speed drives and possible damage.The adhesive can damage the disc and eventually make it unreadable.(Perhaps the claims were being made by a felt tip pen maker) Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 12, 2004 Report Share Posted September 12, 2004 I think the claims made about adhesive labels damaging optical discs may have some validity.If you look carefully at a CD or DVD you will see that the sandwiched reflective layer (the working bit) is much nearer the top of the disc i.e. the top slice of the sandwich is thinner than the bottom so, contrary to what may be thought, the top surface is vulnerable to damage as well as the lower one. This damage could be the adhesive, or the solvent used in the adhesive, of a sticky label leaching down through the relatively thin top of the sandwich and into the reflective layer. Quote Link to comment Share on other sites More sharing options...
nellie2 Posted September 12, 2004 Report Share Posted September 12, 2004 What printer?Epson R300 Quote Link to comment Share on other sites More sharing options...
Chris Posted September 12, 2004 Author Report Share Posted September 12, 2004 Same printer as pops :lol: Quote Link to comment Share on other sites More sharing options...
artist Posted September 12, 2004 Report Share Posted September 12, 2004 I use a felt tip pen - how else do you do it? :confused:me too........... Quote Link to comment Share on other sites More sharing options...
D4\/!d Posted September 12, 2004 Report Share Posted September 12, 2004 me too........... I bet yours are much neater than my scribblings. I even try to Draw the letters, but they still look a mess. Well the surface is so slippery and shiny. :rolleyes: Quote Link to comment Share on other sites More sharing options...
