gillian7117 Posted September 24, 2004 Report Share Posted September 24, 2004 Hello,While i was having a looky through my pc i came across this dead end lolit gives me list of damaged programs, the ones that annoy me the most are panda and pc pitstop because when i want to use their sites it doesnt work anymore.The thing is how do i remove these damaged programs from the list?I got to the list by doing;START -HELP AND SUPPORT -[uSE TOOLS TO VIEW YOUR COMPUTERS INFORMATION AND DIAGNOSE PROBLEMS] -ADVANCED SYSTEM INFORMATION -VIEW DETAILED SYSTEM INFORMATION -INTERNET SETTINGS -CACHE -LIST OF OBJECTS -ta daa lolAny help would be appriciatedI just need to know how to remove or repair the damaged programsThanx alot xxx Quote Link to comment Share on other sites More sharing options...
mark2 Posted September 24, 2004 Report Share Posted September 24, 2004 The panda and Pc pitstop programs I think are ActiveX and will be in your Downloaded program files folder.you should be able to delete them and on your next visit to the sites, you'll be asked to download the programs again. Quote Link to comment Share on other sites More sharing options...
gillian7117 Posted September 24, 2004 Author Report Share Posted September 24, 2004 yeah i think it is the activeX. ive tried everything that the help tells me including the download folder, the damaged files just come up as a list that cant be modyfied, so i need to know if there is some way to delete these somewhere where im not looking. ive done all the things like emptying temporary files ect but this list doesnt alter no matter what i do!so where is a list that i can modify these damaged programs lolThanks alot for all ur help xx Quote Link to comment Share on other sites More sharing options...
Boris Posted September 24, 2004 Report Share Posted September 24, 2004 You can use Disk Cleanup to delete ActiveX controls and Java applets that were downloaded automatically from the Internet when you viewed certain pages?You can view them by clicking the button.Or view + delete them from here C:\WINDOWS\Downloaded Program Files ? Quote Link to comment Share on other sites More sharing options...
gillian7117 Posted September 25, 2004 Author Report Share Posted September 25, 2004 Yup, I tried all that lolthe only place where i can see why these sites dont work anymore is by doing what i did in the 1st post.I cant find where to manualy delete these damaged parts to remove them.All the things like disc clean etc have not worked.Could some1 try doing the steps in the 1st post so you can see what i was looking at, to see a list of damaged parts? I dont know how to do a snap shot of the screen im viewing or i would put it on here lolAll i know is that it is doing my head in lolIn the list it says utility and class alot!My leaving message is.......... i wish i was a computer whizz lol Quote Link to comment Share on other sites More sharing options...
christmascracker Posted September 25, 2004 Report Share Posted September 25, 2004 In internet explorer go to tools, internet options, settings, view objects and you should get the same list.Right click on the damaged ones and you should be able to select update. See if that repairs them.Or you can delete them if you wish. Quote Link to comment Share on other sites More sharing options...
gillian7117 Posted September 25, 2004 Author Report Share Posted September 25, 2004 Ive tried all that and nothing works because there isnt anything in the folder to repair or delete.Its a mystery to me.It must be realy deep in me pc where these damaged files are because like ive said above ive done the obvious things and they arnt solving my problem lol Quote Link to comment Share on other sites More sharing options...
christmascracker Posted September 25, 2004 Report Share Posted September 25, 2004 So if you follow the steps in your first post, what do you see exactly?This is what I see when I follow the steps you gave Quote Link to comment Share on other sites More sharing options...
gillian7117 Posted September 25, 2004 Author Report Share Posted September 25, 2004 Yes thats what i get to. But where it says Status..Installed, mine says damaged lolBut...... i cant find the installed classes that are damaged to delete, thats what i want some1 to tell me lolUrm.....how did you get the snapshot....thats another question lol thanks for all ur help on this xx Quote Link to comment Share on other sites More sharing options...
bvw Posted September 25, 2004 Report Share Posted September 25, 2004 C/Windows/Downloaded Program Files.........You should see this: Quote Link to comment Share on other sites More sharing options...
gillian7117 Posted September 26, 2004 Author Report Share Posted September 26, 2004 yes and where it says installed on yours it says damaged on mine lol xx Quote Link to comment Share on other sites More sharing options...
christmascracker Posted September 26, 2004 Report Share Posted September 26, 2004 Yes thats what i get to. But where it says Status..Installed, mine says damaged lolBut...... i cant find the installed classes that are damaged to delete, thats what i want some1 to tell me lolUrm.....how did you get the snapshot....thats another question lol thanks for all ur help on this xxC/Windows/Downloaded Program Files right click on the damaged file and choose delete or are you saying you dont get this option?I use hoversnap to take screen shots, you can get it from http://www.hoverdesk.net/freeware.htm Quote Link to comment Share on other sites More sharing options...
gillian7117 Posted September 27, 2004 Author Report Share Posted September 27, 2004 In C/Windows/Downloaded Program Files it doesnt give me the option to delete the damaged files because they are not there to delete. I didnt even know why i cudnt use those sites untill i found that list with the programs in it and in there they are listed as damaged. Thats the problem i have. It only tells me they are damaged in the list but doesnt give me the option to delete them in the list or the other places where they should be to delete them lolxx Quote Link to comment Share on other sites More sharing options...
christmascracker Posted September 27, 2004 Report Share Posted September 27, 2004 yes and where it says installed on yours it says damaged on mine lol xxGo to where the list is and tell me what options you get if you right click on one of the damaged files? You should see the same as the screenshot below.Click on remove. When you next go to a website that needs the activeX you will be asked to download it Quote Link to comment Share on other sites More sharing options...
expertec Posted September 27, 2004 Report Share Posted September 27, 2004 Or post a Hijackthis log, DPFs can be removed using Hijackthis. Quote Link to comment Share on other sites More sharing options...
gillian7117 Posted September 27, 2004 Author Report Share Posted September 27, 2004 Cant a moderator or someone that knows how to fix things like this go into my pc and do it for me cos im lost lol Quote Link to comment Share on other sites More sharing options...
gillian7117 Posted September 27, 2004 Author Report Share Posted September 27, 2004 Is there a windows site that can do this for people? Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 27, 2004 Report Share Posted September 27, 2004 I see from your other post http://www.windowsforum.org/forum/index.ph...topic=13191&hl= that you have Kazaa installed in your machine.This could go a long way to explain the problems you are having. Kazaa is a well known vector of all sorts of things that most people would wish were not in their computer including viruses, trojans, adware, spyware, in fact, any and all examples of malware. Quote Link to comment Share on other sites More sharing options...
gillian7117 Posted September 27, 2004 Author Report Share Posted September 27, 2004 Ive got kazza lite++, i dont think it has adware n spyware. I know what u mean bout downloading viruses n that but i need to have my charmed n CSI fixes so its all good lolI sent you a mesage a bit ago pops by accident im sorry bout that xx Quote Link to comment Share on other sites More sharing options...
-pops- Posted September 27, 2004 Report Share Posted September 27, 2004 No problem sending the message - I've replied.About Kazaa and Kazaa lite. The lite version may well be nasties free itself but, you still have to trust the computer that you get connected to doesn't have an infection of something or other.I have heard stories and seen the results of Kazaa, Napster and similar programs more often than I would care to. :( Quote Link to comment Share on other sites More sharing options...
andsome Posted September 27, 2004 Report Share Posted September 27, 2004 If someone uploads a load of junk to the website on a track, and you download it, you are liable to download that junk onto your computer. An anti virus program is only as good as it's latest update, and if someone has picked up a new virus, then sends it to kazaa, they will happily send it to you. If you want something for nothing, you have to risk the consequences. Quote Link to comment Share on other sites More sharing options...
