Internet Explorer Problem
I've heard of this problem before - without much success in curing it, unfortunately. It happens with some banking sites and the user blames the bank and the bank blames the user's computer.
If you're on ME or XP you could try a System Restore.
Also, not much help to you now, but could be in the future, is I ALWAYS make a backup of my system before installing any hardware or software into my machines - just in case of something like you're experiencing
All websites ?
In IE go to view > encoding >select western european
does that help ?
Are you suggesting Western European ISO or Western European Windows? Mine was set at ISO, I have switched to Windows to try it out, but cannot at this stage see anything different.
Why change it if it's working ? If it ain't broke don't fix it :D
However in IE & FirefoxI have Western European ISO and in Opera W E 1252 (windows) all as originally installed (defaults ? ).
Since changing it I noticed that it had changed back when I next had a look. I tried setting it to Auto select, and it now changes from page to page, and site to site. Have a look and see if your settings do the same.
