Guest Nellie2 Posted June 1, 2003 Report Share Posted June 1, 2003 Well the f-ing thing has crashed about five times in the last 10 mins.Here is the error log for today!!01 June 2003 Applicatio n Error Faulting application helpctr.exe, version 5.1.2600.1106, faulting module kernel32.dll, version 5.1.2600.1106, fault address 0x0001a67a. 01 June 2003 DrWatson The application, C:\WINDOWS\PCHealth\HelpCtr\Bi naries\HelpCtr.exe, generated an application error The error occurred on 06/01/2003 @ 19:42:19.678 The exception generated was c0000005 at address 77E7A67A (kernel32!InterlockedDecrement ) 01 June 2003 TlntSvr WSAGetLastError() returned error: An address incompatible with the requested protocol was used. 01 June 2003 TlntSvr WSAGetLastError() returned error: An address incompatible with the requested protocol was used. 01 June 2003 TlntSvr WSAGetLastError() returned error: An address incompatible with the requested protocol was used. 01 June 2003 TlntSvr WSAGetLastError() returned error: An address incompatible with the requested protocol was used. 02 June 2003 TlntSvr WSAGetLastError() returned error: An address incompatible with the requested protocol was used. I have to tax my pigging car tomorrow too!!! :( Quote Link to comment Share on other sites More sharing options...
bvw Posted June 1, 2003 Report Share Posted June 1, 2003 Check for a trojan nellie. Quote Link to comment Share on other sites More sharing options...
Chris Posted June 2, 2003 Report Share Posted June 2, 2003 Hmmm...The helpctr.exe is just the help and support from the start menu.How the hell that is crashing your computer do not know.Have you tried SFC /SANNOW from the run command?Also ther Kernel32.dll is a pretty imporant Windows File.(always wanted to attach this :P ) Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted June 2, 2003 Report Share Posted June 2, 2003 nel can you disable the telnet service as that what the TlntSvr WSAGetLastError() returned error: An address incompatible with the requested protocol was used. is about,when you say freeze does ctrl/alt/delete not bring up task manager. Quote Link to comment Share on other sites More sharing options...
Guest Nellie2 Posted June 2, 2003 Report Share Posted June 2, 2003 No Trojans........... did a scan with The cleaner.Couldn't run the SFC scan now thing......... tried twice and both times it locked up.... so I did a repair in the end!!! Again!!!!Have disabled the telnet thing Ellas.When I say lock up I mean just that........... no ctrl /alt/ del even pressing the windows key won't bring up the start menu............. totally nothing. Quote Link to comment Share on other sites More sharing options...
madboy33 Posted June 2, 2003 Report Share Posted June 2, 2003 go to start>control panel > network and internet connections>then network connectionsIf you can see a dialler there for your modem, delete it.Now turn the computer off, remove the modem and rebootThat may do it nells Quote Link to comment Share on other sites More sharing options...
Guest Nellie2 Posted June 5, 2003 Report Share Posted June 5, 2003 Thought you might like a bit of an update.... after some discussion and a lot of PM's and a bit of remote assistance etc I have come to the conclusion that my problem is a hardware one. I was having a kernel dll error now and then which points to a hard drive problem sometimes!!! Anyway, I have more or less tried all the fiddling around I can do so I have decided to treat myself to a new hard drive.I have been having a rummage around the Novatech site and have ordered a rather nice 60gig one for £56.93 inc vat + £3.00 delivery.I will let you know how I get on when it arrives. :) Quote Link to comment Share on other sites More sharing options...
Boris Posted June 5, 2003 Report Share Posted June 5, 2003 I can't get into the Novatech site - it just does nothing !Every other site seems to be OK though <_> Quote Link to comment Share on other sites More sharing options...
Guest Nellie2 Posted June 5, 2003 Report Share Posted June 5, 2003 You are going via this address I take it???http://www.novatech.co.uk/novatech/home.html Quote Link to comment Share on other sites More sharing options...
Boris Posted June 5, 2003 Report Share Posted June 5, 2003 Yes Nel - as usual.Seems OK now :blink: Quote Link to comment Share on other sites More sharing options...
Boris Posted June 5, 2003 Report Share Posted June 5, 2003 I have been having a rummage around the Novatech site and have ordered a rather nice 60gig one for £56.93 inc vat + £3.00 delivery.Which one ? Nothing showing at that price ?If I was in the H/D market I would have gone for the :-DiamondMax Plus9 80Gb 2Mb Cache Hard Disk Drive ATA 133 Admittedly a bit more but bigger, very quiet + ATA133 Quote Link to comment Share on other sites More sharing options...
Boris Posted June 5, 2003 Report Share Posted June 5, 2003 I will let you know how I get on when it arrives. :)What is their delivery service like ? Quote Link to comment Share on other sites More sharing options...
Guest Nellie2 Posted June 5, 2003 Report Share Posted June 5, 2003 Here is the link.............. it is the one at the bottom of the pagehttp://www.novatech.co.uk/novatech/Storage...0d0e0x0y1z2p1m0I did think about the 80gig one but I really don't know what I would do with all that space........ also I was trying to stay under £50.... ok, I know I went over but only a little bitAs you can see......... this one has the same specs, just a tad smaller!!! :) Quote Link to comment Share on other sites More sharing options...
mark2 Posted June 5, 2003 Report Share Posted June 5, 2003 I ordered a USB 2 card from them Saturday here in Mondays post, as good as crucial I think Quote Link to comment Share on other sites More sharing options...
Guest Nellie2 Posted June 5, 2003 Report Share Posted June 5, 2003 BTW........... I priced some hard drives in a well known store......not PCW but another one, in fact a couple. Anyway, high street prices seem to be about £70 for a 40gig 5400rpm drive!!!!........so you can save a lot by doing your shopping on line!!! Quote Link to comment Share on other sites More sharing options...
Boris Posted June 5, 2003 Report Share Posted June 5, 2003 As you can see......... this one has the same specs, just a tad smaller!!! :)DiamondMax Plus9 60Gb 2Mb Cache Hard Disk Drive ATA 133 :D Quote Link to comment Share on other sites More sharing options...
Boris Posted June 5, 2003 Report Share Posted June 5, 2003 I ordered a USB 2 card from them Saturday here in Mondays post, as good as crucial I thinkWas that their "Premium" service or the standard 3/5 working days ? Quote Link to comment Share on other sites More sharing options...
Boris Posted June 5, 2003 Report Share Posted June 5, 2003 I ordered a USB 2 card from them Saturday here in Mondays post, as good as crucial I thinkI got a brand new PCI USB 2.0 card with 4 rear ports + 2 more on the card itself for £12.00 at Whitchurch on Sunday.I think it was wrongly priced ? - but my mate was delighted. Quote Link to comment Share on other sites More sharing options...
Guest Nellie2 Posted June 5, 2003 Report Share Posted June 5, 2003 I know I know........... an extra 20gig for very little but then the price just creeps up doesn't it!!!! I decided that 60 would be enough for me.It actually came to £56.93 at the checkout.........so an extra 53p was added in the vat calc somewhere I think. I have ordered mine with just the 3/5 day delivery............ I will let you know when it actually arrives. Quote Link to comment Share on other sites More sharing options...
mark2 Posted June 5, 2003 Report Share Posted June 5, 2003 Ordered on their standard 3/5 days, but came in normal post, something bigger/heavier may take longer. :blink: Quote Link to comment Share on other sites More sharing options...
Guest Nellie2 Posted June 6, 2003 Report Share Posted June 6, 2003 I placed my order with Novatech yesterday lunchtime, I just asked for the normal 3/5 days delivery and today the postman tried to deliver a parcel.......... but it wouldn't fit through my letter box. I shall pick it up from the sorting office tomorrow morning!!!I wonder what it is????? :lol: :lol: :lol: Quote Link to comment Share on other sites More sharing options...
Chris Posted June 6, 2003 Report Share Posted June 6, 2003 eh? Your buying a new HDD for the sake of errors?Reformat and reinstall - saves money, but a time killer - Then do one thing at a time. Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted June 6, 2003 Report Share Posted June 6, 2003 what happens nel if its not the h/drive :o :D Quote Link to comment Share on other sites More sharing options...
Boris Posted June 6, 2003 Report Share Posted June 6, 2003 Yes ellas, but if it is ?BTW What happens to the old one ? Re-cycling ?I could replace the dodgy 8 gig one in this (if Nel was open to a reasonable offer for it ?) :D Quote Link to comment Share on other sites More sharing options...
Guest Nellie2 Posted June 6, 2003 Report Share Posted June 6, 2003 Reformat and reinstallBelieve me powerless............ I have done that more than once... :( If I still get the problem after I have changed the hard drive then I don't know............. I am stumped!! PC murder I think.My current hard drive is going to go into another puter, sorry Boris...... but to be honest, I don't think I would trust it, that is if my problem does go away with the change of hard drive. Quote Link to comment Share on other sites More sharing options...
