Graphics in post
Thos
I wonder if I have missed this topic but where has the "add graphic" option gone in new posts or replies? I used to browse to something on my hard drive, click "add to post" and the graphic or whatever would appear in the post (providing it was small enough).
Now that option has disappeared and I cannot send you a screenshot to show where it isn't, if you get my meaning!
Thos.
Underneath the text box is an attachment box... if you look to the right you will see a browse button and an upload button
Underneath my text box is: on the left a box which says "Toggle Side Panel" and on the right a box which says BB Code Help.
Below that frame is another frame with Post Options and a HTML Off box, underneath which are tick boxes Enable emoticons ? and Enable signature ?
Below that frame is another frame Post Icons (optional)
Below that frame there are the "Add Reply" and "Preview Post" boxes.
No attachment box, no browse button as there used to be.
Thos.
Thanks for the screen shots, rong and nellie but that whole attachment panel is missing. As I said, I cannot send you a screenshot of my screen showing you it isn't there!
Is it there on the default skin for you, Thos?
Good thinking, pops, but no, it doesn't show up on the default skin either. Am I the only one then?
:( :( :( Thos.
1.Following CurlyWhirly's link (thanks) the above is a screenshot of my reply page.
2. I emptied the browser cache as suggested and had the utmost difficulty logging in again to the Forum. It would not recognise me and I have had to get a new password to log in once more.
What on earth is happening?
Thos.
ps. still no options for attachments.
Thos,
I'm 99% sure the problem lies at your end.
The scren shot shows at the bottom of IE "error on the page".
I see you are using mcafee, is it possible to disable the IE addon to see if this resolves your problem?
Thos,
I have disabled the McAfee site advisor but it has not resolved the problem.
Chris sent me a PM suggesting he should change the log-in details. I agree, of course, but cannot send a PM in reply. Even though only 1% of my message box is taken up (1 message) I keep being told that I have used up all my allocated space. New screenshot below.
Thos.
Thos you should have an email with your new password! When changing your password there are 2 options I can select hopefully they have solved your password/login problem.
However back to this topic I'm afraid to tell you that, it looks as if it is something on your PC that is preventing you from seeeing the attachments.
As you can ses below I loged in as yourself [as discussed in the PM] and the attachment panel is there and waiting...I tried it in 3 different browsers and they all show the attachments panel.
