Panarchy Posted February 4, 2007 Report Share Posted February 4, 2007 HI!Recently my dad gave me a mouse that some doctor friend of his had given him. It is a wireless mouse. And as of yet, I haven't got it to work. :( I have XP Pro, and when I inserted the USB it said new hardware has been found. Then it said that it has been installed correctly and should work.It doesn't.Please help,Panarchy Link to comment Share on other sites More sharing options...
rong Posted February 4, 2007 Report Share Posted February 4, 2007 You have to have the signal box away from anything magnetic, screen psu etc. so if you haven't done so try moving it around. Link to comment Share on other sites More sharing options...
andsome Posted February 4, 2007 Report Share Posted February 4, 2007 Silly question perhaps, but are the batteries OK? Link to comment Share on other sites More sharing options...
-pops- Posted February 4, 2007 Report Share Posted February 4, 2007 Try this:The signal receiver box will have a button on it to enable tuning to the transmissions of the mouse. Also the mouse will have a reset button (probably accessed by a pin or paperclip) on the underside.Reset the mouse and then reset the receiver box - give each about a minute to settle before expecting either to work properly. Link to comment Share on other sites More sharing options...
Thos Posted February 4, 2007 Report Share Posted February 4, 2007 Silly question perhaps, but are the batteries OK?That's not silly. It is fundamental.And does it need a driver?Thos. Link to comment Share on other sites More sharing options...
rong Posted February 4, 2007 Report Share Posted February 4, 2007 Mine only needs extra things loaded to be able to use all the extra things on the mouse. Link to comment Share on other sites More sharing options...
andsome Posted February 4, 2007 Report Share Posted February 4, 2007 Mine only needs extra things loaded to be able to use all the extra things on the mouse.Same here, it does a basic job without drivers, but is much better with them. Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted February 6, 2007 Report Share Posted February 6, 2007 And does it need a driver?Most cordless devices need a device-specific driver. Link to comment Share on other sites More sharing options...
Panarchy Posted February 6, 2007 Author Report Share Posted February 6, 2007 I don't know what brand mine is so that is no help.I tried the other things, they didn't work either. Link to comment Share on other sites More sharing options...
-pops- Posted February 6, 2007 Report Share Posted February 6, 2007 I don't know what brand mine is so that is no help.I don't understand why you don't know the brand name - it is normally on the underside of the mouse - if not on the top and on the receiver unit as well.I'm tempted to ask now: if these identifiers have been removed, does the mouse belong to the receiver unit you are trying to use it with - are they a matched pair? Link to comment Share on other sites More sharing options...
Scarecrow Man Posted February 6, 2007 Report Share Posted February 6, 2007 If it's bluetooth, you will almost certainly need a driver. Link to comment Share on other sites More sharing options...
artist Posted February 7, 2007 Report Share Posted February 7, 2007 Having just had a problem with my mouse - Logitech laser with keyboard - It kept on juddering - I removed the lot, including all the bits from a 'search' and CCleaner. Reinstalled and all seems well now.Did you try a reinstall? Link to comment Share on other sites More sharing options...
Panarchy Posted February 7, 2007 Author Report Share Posted February 7, 2007 Try this:The signal receiver box will have a button on it to enable tuning to the transmissions of the mouse. Also the mouse will have a reset button (probably accessed by a pin or paperclip) on the underside.Reset the mouse and then reset the receiver box - give each about a minute to settle before expecting either to work properly.It worked. I didn't notice the button on the mouse before. Thanks Link to comment Share on other sites More sharing options...
Panarchy Posted February 7, 2007 Author Report Share Posted February 7, 2007 I will close this topic now. Link to comment Share on other sites More sharing options...
