volcom Posted July 29, 2003 Report Share Posted July 29, 2003 Well i left for a week for michigan, and i got a call from my mom saying when she started the computer and logged onto her name (on windows xp) all she got was the background. I told her i would work on it when i got home. I came home and saw what she was talking about, when you logged onto your name, all you would get was a blank background, no icons, no start menu nothing (you cant even right click). I was able to open my task manager (ctrl+alt+del) and kill the explorer.exe process and force it to run again by file>run new task>explorer.exe (all in task manager). And magically it worked. I had icons and a start menu. Then my virus software alerts me a possible virus has been detected. So i scan my computer and find an exploit and one virus. I delete both of them, and reboot my computer. Once again no icons, or a start menu. I end explorer, and force run it again (as i did before) and notice three programs are running smbp, nmp, and unwise.exe, which i kept getting errors for. (not exactly sure if thats the exact name for the second one) i find them and delete them, now on boot up everythings normal except i get a ton of errors: " Cannot find and execute C:\windows\unwise.exe""Cant Load unwise" "try removing from registry"...ect. Also no *.exe will execute. I cant start AIM, Kazaa, mIrc, Yahoo... im only allowed into excel, internet explorer, word, notepad... stuff like that... any ideas how to get my comptuer back to normal??????? Some one please help me i would be forever grateful!!!!! :( :( :( :( Quote Link to comment Share on other sites More sharing options...
Guest northamuk Posted July 29, 2003 Report Share Posted July 29, 2003 You expect a reply when you register as **** ****, I don't think so. Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted July 29, 2003 Report Share Posted July 29, 2003 I have removed the name he used in his profile,may have to suspend his account also. Quote Link to comment Share on other sites More sharing options...
Agent Smith Posted July 29, 2003 Report Share Posted July 29, 2003 Just in case this is a genuine enquiry, and for the benefit of anybody else who may have got themselves into the same bother, I have just checked the Norton website and have come up with the following Backdoor.NetTrojanConsidering the list of "programs" that the postee is unable to use, I am not surprised he has a problem. The above link contains detailed instructions for how to clean up the mess made in the registry by this trojan. But personally I think you should erase the hard disc and start again, this time leaving off your file sharing programs!!!I also presume that you have a decent system restore point (likely :lol: ), you could try using that. And in future, make sure your av and personal firewalls are up todate and running.Mr. Mouse. Quote Link to comment Share on other sites More sharing options...
Redhat Posted July 29, 2003 Report Share Posted July 29, 2003 How about System Restore to a point before all this :rolleyes: Quote Link to comment Share on other sites More sharing options...
Tankus Posted July 29, 2003 Report Share Posted July 29, 2003 I had backdoor fraggle ,which got picked up after an update from AVG .......Bloody hard to to get rid of as it kept rebooting form god knows where even after AVG isolated it ..........Finally did a restore point back one month after running just about every thing I had..... including a multi-pass slack space deleter.......Bit piggy........Post looks a bit of a wag , but so what...!.............. cheers **** **** Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted July 29, 2003 Report Share Posted July 29, 2003 EXE File Association Fix for Windows XPThis download restores the default File Association for EXE files. Download the REG file and save it to your hard drive. Double click the file you just saved and answer yes to the import prompt. REG files can be viewed in Notepad by right clicking the file and selecting Edit. http://www.kellys-korner-xp.com/regs_edits.../xp_exe_fix.reg Quote Link to comment Share on other sites More sharing options...
Tankus Posted July 29, 2003 Report Share Posted July 29, 2003 Ill ask you next time if I get stuck ....ellas.....might save me a lot of time.....! Quote Link to comment Share on other sites More sharing options...
Guest moon Posted July 29, 2003 Report Share Posted July 29, 2003 Weird. Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted July 29, 2003 Report Share Posted July 29, 2003 whats weird :unsure: Quote Link to comment Share on other sites More sharing options...
Tankus Posted July 29, 2003 Report Share Posted July 29, 2003 What ....asking ellas for advice ...moon ...? Quote Link to comment Share on other sites More sharing options...
Chris Posted July 29, 2003 Report Share Posted July 29, 2003 You expect a reply when you register as **** ****, I don't think so.How about a **** **** on the underlined. Quote Link to comment Share on other sites More sharing options...
madboy33 Posted July 29, 2003 Report Share Posted July 29, 2003 done powerless Quote Link to comment Share on other sites More sharing options...
Guest northamuk Posted July 29, 2003 Report Share Posted July 29, 2003 You might as well do this one too.I had backdoor fraggle ,which got picked up after an update from AVG .......Bloody hard to to get rid of as it kept rebooting form god knows where even after AVG isolated it ..........Finally did a restore point back one month after running just about every thing I had..... including a multi-pass slack space deleter.......Bit piggy........Post looks a bit of a wag , but so what...!.............. cheers **** ****--------------------.............................................Tankus....................................................If you are going to do it, then do it right, Quote Link to comment Share on other sites More sharing options...
Chris Posted July 29, 2003 Report Share Posted July 29, 2003 :o Quote Link to comment Share on other sites More sharing options...
Tankus Posted July 29, 2003 Report Share Posted July 29, 2003 oh....my my.......! Quote Link to comment Share on other sites More sharing options...
Gandalph Posted July 30, 2003 Report Share Posted July 30, 2003 I noticed in volcom's post that he is using Kazaa.......I wonder where he got the Virus from? Quote Link to comment Share on other sites More sharing options...
mark2 Posted July 30, 2003 Report Share Posted July 30, 2003 I wonder !!!! :P Quote Link to comment Share on other sites More sharing options...
