cinque8 Posted November 6, 2017 Report Share Posted November 6, 2017 Hello, I am running Windows 7 on my laptop computer. The background color on my desktop is black. I right clicked on my desktop changed the background color to blue and saved the changes. But when I restart my computer, the background color returns to black. I have done this several times. How can I permanently change my background color to blue? Thank you Quote Link to comment Share on other sites More sharing options...
andsome Posted November 7, 2017 Report Share Posted November 7, 2017 Google is frequently your best friend for this sort of problem https://www.google.co.uk/search?source=hp&ei=3WgBWu-5MdHDkgX8oI2QAw&q=change+background+colour+in+windows+7&oq=change+background+colour+in+windows+7&gs_l=psy-ab.3..0j0i22i30k1l9.1966.19122.0.19709.37.37.0.0.0.0.163.3624.26j11.37.0....0...1.1.64.psy-ab..0.37.3607...46j0i131k1j0i46k1j0i3k1.0.LtfbbBgkRQ8 Quote Link to comment Share on other sites More sharing options...
Irene Posted November 7, 2017 Report Share Posted November 7, 2017 You could try running the SFC /SCANNOW command file checker. Tutorial HERE (and includes the quote below): Quote The sfc /scannow command (System File Checker) scans the integrity of all protected Windows 7 system files and replaces incorrect corrupted, changed/modified, or damaged versions with the correct versions if possible. Quote Link to comment Share on other sites More sharing options...
cinque8 Posted November 7, 2017 Author Report Share Posted November 7, 2017 12 hours ago, andsome said: Google is frequently your best friend for this sort of problem Thank you for the information Andsome Quote Link to comment Share on other sites More sharing options...
cinque8 Posted November 7, 2017 Author Report Share Posted November 7, 2017 11 hours ago, Irene said: You could try running the SFC /SCANNOW command file checker. Thank you for the information Irene Quote Link to comment Share on other sites More sharing options...
Irene Posted November 7, 2017 Report Share Posted November 7, 2017 You are welcome, cinque8. I hope it helps to resolve your problem. Quote Link to comment Share on other sites More sharing options...
andsome Posted November 8, 2017 Report Share Posted November 8, 2017 Is the problem solved? Quote Link to comment Share on other sites More sharing options...
cinque8 Posted November 8, 2017 Author Report Share Posted November 8, 2017 4 minutes ago, andsome said: Is the problem solved? I followed your suggestion and ran sfc /scannow but I still have the problem. But thank you for asking. Quote Link to comment Share on other sites More sharing options...
-pops- Posted November 8, 2017 Report Share Posted November 8, 2017 How long has your machine had this black background? You may be able to carry out a System Restore to a time before this happened. Quote Link to comment Share on other sites More sharing options...
cinque8 Posted November 8, 2017 Author Report Share Posted November 8, 2017 Quite a while. How do you do a system restore? Quote Link to comment Share on other sites More sharing options...
-pops- Posted November 8, 2017 Report Share Posted November 8, 2017 The simplest way is to open Control Panel and write system restore in the search box (top, right). Follow the instructions you are given then. Quote Link to comment Share on other sites More sharing options...
Boris Posted November 8, 2017 Report Share Posted November 8, 2017 If you need it, this could be of some help - https://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/ Quote Link to comment Share on other sites More sharing options...
morty Posted November 8, 2017 Report Share Posted November 8, 2017 cinque8 ... I run windows 7 and got in a mess a while back trying to change my desktop background colour. Mine only seemed to stay to what I changed it to when I avoided the pesky Themes section and went around the long way Control Panel> Appearance & Personalisation , which has Change Desktop Background in the menu. In there I set the colour I wanted and it's stayed that way. Quote Link to comment Share on other sites More sharing options...
cinque8 Posted November 8, 2017 Author Report Share Posted November 8, 2017 Thanks everyone, now it seems to be working. Thank you. Quote Link to comment Share on other sites More sharing options...
