Belatucadrus Posted July 13, 2018 Report Share Posted July 13, 2018 Quote Link to comment Share on other sites More sharing options...
Gandalph Posted July 13, 2018 Report Share Posted July 13, 2018 Its amazing what you can get away with in a country that doesn't have M.o.T's. Quote Link to comment Share on other sites More sharing options...
AlanHo Posted July 13, 2018 Report Share Posted July 13, 2018 Did you use the word breaking in lieu of braking deliberately?....... Quote Link to comment Share on other sites More sharing options...
Belatucadrus Posted July 13, 2018 Author Report Share Posted July 13, 2018 43 minutes ago, AlanHo said: Did you use the word breaking in lieu of braking deliberately?....... Maybe, maybe not I never brake the rules, just bend them into exotic and peculiar shapes. Quote Link to comment Share on other sites More sharing options...
catgate Posted July 13, 2018 Report Share Posted July 13, 2018 It would be nice to know just how satisfactory it is in use. Presumably it is a set up for garage use. Quote Link to comment Share on other sites More sharing options...
Belatucadrus Posted July 13, 2018 Author Report Share Posted July 13, 2018 2 hours ago, catgate said: Presumably it is a set up for garage use. I think you're trying to apply logic rather than being gobsmacked at the lunatic bodging of some of our eastern European brethren. Quote Link to comment Share on other sites More sharing options...
catgate Posted July 14, 2018 Report Share Posted July 14, 2018 "I think you're trying to apply logic rather than be..........." So...you also think that there is a little bit of logic to be found, if the correct corners are found? Quote Link to comment Share on other sites More sharing options...
andsome Posted July 14, 2018 Report Share Posted July 14, 2018 It’s not as bad as a Trabant Quote Link to comment Share on other sites More sharing options...
