Ewido scans for Malware
Shirley Crabtree
I was recently asked to look at a relatives Pc as there was obviously something amiss.
AVG found nothing...Spybot S&D found nothing in particular...Trojan Hunter found nowt...MS Antispyware found sod-all and Adaware flagged the usual cookies :rolleyes:
I KNEW there was something wrong so ran a pandascan...It found 219 spyware .exes all over the HDD but it doesn't disinfect these files....Great thinks I....219 files to manually delete in safe mode.
Then I remembered about Nellie telling me about Ewido...I did an online scan with Ewido :-
http://www.ewido.net/en/
And lo and behold...It found 219 spyware files and deleted the lot of them.
Why doesnt Spybot S&D,Adaware or MS Antispyware see these files?...Thats what I'd like to know :S
Spyware is evolving!!!!
The trusted old safeguards dont seem up to the job nowadays :(
Interesting! I just ran the Ewido online scan, and it found over 500 spyware cookies that CCleaner did not see
That seems rather a lot of spyware cookies - 500 :o
Spybot, Ad-aware and a-squared occasionally find a few spyware cookies on my PC.
Incidentally, I also ran Ewido online scan and it only found 1 spyware cookie which was a false positive as the so called spyware cookie was in actual fact a PC forum that I am registered with!
I ran Ewido also and it found 2 "high risk" spywares lurking. It took about 15 minutes against about 35 minutes for AVG, 20 mins for a-squared and about 3 for Spybot. Anyone know if the time taken to do these scans bears any relation to their thoroughness?
Thos.
I think AVG and Ewido look for different things.
I am quite impressed with Ewido. Just tried on my other machines and found a few bits of malware on both - missed again by my previous scanners.
Looks pretty good andsome. Have you done the full download and scan from that yet?
As I said, I only got a few minor things on mine - perhaps it indicates how pure our Internet activities are :P :blink:
I did the online scan.
Just tried the online scan from Ewido and like andsome it found nothing. In fact it did the scan in under a second and said done. Wonder if it's working properly. I did notice that it was a beta version.
Should we start a fresh topic on this?
I don't think that that was right. My scan took several minutes.
After cleaning 6 registry entries and the 500+ spyware cookies (using the downloaded trial version), I ran the online beta scan again. It found ... 500+ spyware cookies! :ninja:
So this time I had a closer look at where these "hidden" cookies are kept, as Ccleaner did not find any of them. They are in
C:\Documents and Settings\myuserid.DOMAIN\Application Data\Mozilla\Firefox\Profiles\m83os0gp.default\cookies-1.txt
C:\Documents and Settings\myuserid.DOMAIN\Application Data\Mozilla\Firefox\Profiles\m83os0gp.default\cookies-2.txt
C:\Documents and Settings\myuserid.DOMAIN\Application Data\Mozilla\Firefox\Profiles\m83os0gp.default\cookies-3.txt
C:\Documents and Settings\myuserid.DOMAIN\Application Data\Mozilla\Firefox\Profiles\m83os0gp.default\cookies-4.txt
C:\Documents and Settings\myuserid.DOMAIN\Application Data\Mozilla\Firefox\Profiles\m83os0gp.default\cookies-5.txt
Now that is curious - is this where Firefox keeps its cookies? If this is the case, then neither Ccleaner nor Ad-aware nor Spybot S&D knows about this.
I will post a query in the Firefox forum and report back here.
Ok, I think I got it now. Firefox cookies are kept in this file
C:\Documents and Settings\myuserid.DOMAIN\Application Data\Mozilla\Firefox\Profiles\m83os0gp.default\cookies.txt
This file has today's date, and is rather small. The other files with the numbers in it are older - some dating back to November 2004. I think they are kind of backups from the actual cookies file. All spyware cookies detected by Ewido were in these old files, not in the actual cookie file.
I am going to delete these old files now.
could be that most of the ewido findings were located in system restore folder(s)
unlike most scanners ewido is able to clean those..
it is a very efficient malware solution. boasting a hi-tech scan engine with code/unpacker emulation
i recently received a 3.2 MB scanlog(list of infections:o ) from someone whose machine i was cleaning
i bet you guys dont use spywareblaster, it prevents the spyware cookies even for moz/FF
edit: i just found the report of my lastest ewido scan some weeks ago, thats 12,8 MB and i dont even have archive scanning enabled :o
