Drive C filling up; Drive D empty. Oh my.
KenB
My Acer laptop came with Windows XP installed. It boasts a 60GB hard drive.
In My Computer, under "Hard Disk Drives," it shows that ACER (C:) has a total size of 26.3GB, with 1.68GB of free space. ACERDATA (D:) has a total size of 26.5GB and 26.5GB of free space. So Drive D is virtually unused.
I've been told that Windows will act up in unspecified ways if Drive C goes beyond 90% full. I'm already at 94%. Apparently the computer is not going to automatically put anything into Drive D.
It would seem reasonable to shift some files, especially my data files, to Drive D, but I haven't been able to move My Documents over there. When I tried that, only a shortcut arrived.
I hope you can tell me what I should do about it, and maybe tell me why two drives show when I only have one hard drive in the computer.
You won't be able to move the folder "My documents" to the other drive but you should be able to move the contents there. Create a new folder, call it "My new documents" (or something convenient) and move some of the files from one to the other.
You can do similarly with other folders.
You can move the My Documents folder.
Just right click the My Documents folder, on the start menu or the desktop, and click the Move button. You can then move it to any location you would like, including a different Partition or Physical Drive. You may want to make a new My Documents folder prior to the move, so you can find it easily.
After you do this, when you save to My Documents in ANY program, it will automatically go to the location you have chosen. Also, all of your current files will be moved.
Thanks to the three who have replied so far. The suggestions of pops and doug appear to work. I still don't know why my computer was set up with a D drive.
Scarecrow Man's suggestion looked ideal, but when I tried it, I found that right clicking My Documents did not give me a "move" option.
I have never been able to move the My documents folder which is why I made the suggestion I did.
In any case, it would be better to leave the My documents as, and where, it is then transferring files from there when necessary.
Unfortunately that isn't one of the places suggested by SM.
Even if it is possible to move the folder, as it is one of the fundamental parts of the Windows system, I consider it is best left where it is and its contents moved rather than the folder itself.
I do it to save myself some backup time, since I store a lot of files in the My Documents folder. I back them up to a different physical drive, and then to an external drive.
How to Change the Default Location of the My Documents Folder
If I right click the blue bar I get a move option.
That is not quite the same. That will move the window itself, but not the location. See my reply below.
Sorry. I did not specify, you must right click > properties. Then you will see a move button.
My present Sony desktop computer came with both C & D drives.
I followed the same procedure suggested by Scarecrow man and everything moved successfully. Now whatever I do, My Documents always presents associated with the D drive.... Just like magic! ;)
Many thanks to all who responded. This has turned out to be an excellent resource!
In the end, Scarecrow Man's solution worked for me as it did, apparently, for Irene. My computer heaved a sigh of relief. Now I wonder whether I should defrag or something.
Many thanks to all who responded. This has turned out to be an excellent resource! In the end, Scarecrow Man's solution worked for me as it did, apparently, for Irene. My computer heaved a sigh of relief. Now I wonder whether I should defrag or something.
This forum has been one of the best things I have joined in eons, and I have a few of those under my belt now!! :D
So thats what the big lump is then. :lol: :lol:
Well it's certainly not a baby!! :0
The big lump is contented retiredment. :D
Defrag will free up space ...
Defrag does not free up space - in the sense that not more free space will be available after the defrag. Defrag will merely put file fragments together, so files can be read quicker.
CCleaner is a tool that can free up a lot of space, especially for first-time users.
