Speed test
rong
Could someone please try this speed test sight I have been put onto by my service provider http://www.kbps.co.uk/index.php?option=com...r&Itemid=41 (link should take you straight into the test) and let me know if it is anything near accurate. I have always used http://www.thinkbroadband.com/speedtest.htm before and lately have had really slow results, the tec bloke said they are having problems at the moment.
I have connected to the first link and this is the result (I have no idea what it means),
I hope it makes sense to you, rong. :) .......
My upload and download speeds using your test are 0.36 Mbps and 3.54 Mbps respectively.
My cable connection is rated at 0.384 and 4.0 Mbps - so the results are close to what I normally experience.
I don't understand the translations, Alan, but below are screen dumps of my connection speeds. Are they good or bad? Also, is there anything I could do to improve them?
The sites which I used are the ones used by pops and andsome.
I always use this site http://www.dslreports.com/speedtest for speed testing. The java or flash should produce the same result. I used flash in my example.
My result 24163962.png @ work.
This test showed over 4 meg for my 4 meg connection, as against others which usually show 3.8 plus.
According the the Frog results, Irene, you are getting about half of the rated speed. If you were on BT 2Mb lines, this would be sort of OK. I don't know how cable varies.
Be sure to take readings over a period of time - whole day - as speeds can differ widely depending on the number of users on your particular part of the network.
When I posted the Frog link last night I did a test and got 1.7Mb.sec - dreadfully slow and it showed by my actual download speeds. Did a test just now and got 5.7Mb/sec - which is reasonable for my 8Mb claimed service.
Another tester (used to be known as ADSLGuide) is Thinkbroadband. This is thought by some to be the definitive speed tester it's here.
Edit:
As a rider to andsome's post (above) I occasionally get 12Mb download speeds for short periods. I think this is because where I live is one of the test areas (a chairman of BT used to live down the road) for telecoms development.
Irene
If you subscribe to the basic Virgin Media broadband package M your maximum speeds will be
Upload 0.200 Mbps (your test was 0.174 Mbps)
Download 2.0 Mbps (your test was 1.88 Mbps)
Hence you are running close to maximum speed on that test - but as pops says - checks at various times in the day will produce wild variations in speed due to sharing of bandwidth.
I subscribe to the next package up which gives me twice your speeds - but I'm not boasting. ...... ;)
I have actually been in touch with BT and they are upgrading me from 2 to 8mg, for free! They say it should be operational on the 20th. It'll be interesing to see what difference it makes.
He said that in my locality I may not achieve the full 8mg, could be just 3mg. I don't understand exactly why it should be so, but time will tell. :D
Edit:
The Frog is showing my connection at less than half what the others show. The DEFINITIVE tester is showing much the same as all the others. So perhaps the frog is playing up at present.
I tried the link with thinkbroadband and my results were similar to the others, Speed up: 1.8Mbps, Speed down: 0.2Mbps. I thought it was an interesting site, so I registered and will get an email reminder to check my speeds for comparison. Lots of good info on there. Thanks pops. :flowers:
I wish the upload speeds were better. I joined the BT Vault which I thought would be good to store movies etc., but the upload was painfully slow. It took over 7 hours to uplift one movie!! Then when it said it was complete, I couldn't find the movie. :huh:
Pops, (Another tester (used to be known as ADSLGuide) is Thinkbroadband. This is thought by some to be the definitive speed tester it's here.) that's the one I was using and was showing speeds of around Half a meg, and the other one was just under 4, that is why I phoned my ISP and was told as in my first post.
Thankyou to everyone for responding and will use the one I was pointed to as it seems to be about right.
I think you've missed the posts since you were last on. :D
Unfortunately as we aren't on cable, our broadband speeds are affected by our distance from the BT exchange :(
I live a fair distance from my exchange and only get around half the 8 Mb speed.
The maximum speed available on my connection is 8 Mb, but because of the distance from the exchange I get 4.5 or so at best. I am not complaining because that speed is fine for little old me.
Thos. :rolleyes:
I have actually been in touch with BT and they are upgrading me from 2 to 8mg, for free! They say it should be operational on the 20th. It'll be interesing to see what difference it makes.He said that in my locality I may not achieve the full 8mg, could be just 3mg. I don't understand exactly why it should be so, but time will tell. :D
Unfortunately as we aren't on cable, our broadband speeds are affected by our distance from the BT exchange :( I live a fair distance from my exchange and only get around half the 8 Mb speed.
Well, my 8 Mb are due to become live tomorrow, so it will be interesting to see what mine is then. :D
As BT promised, my "8 Mb" came live yesterday. I repeated two of the speed tests to check what difference it had made.....
thinkbroadband
Prev: Speed Down 1872.43 Kbps; Speed Up 240.39 Kbps
Last: Speed Down 2332.48 kbps; Speed Up 373.97 Kbps
(25% increase on down & 56% increase on up)
InternetFrog.com
Prev: Speed Down 1.94 Mps; Speed Up 173 kbps
Last: Speed Down 2.21 Mps; Speed Up 211 kbps
(14% increase on down & 22% increase on up)
There appears to be quite a difference in the % increases of the two websites. :uhm: Strange..
I'll do them both again today and towmorrow to get an average overall.
Interesting.
My "8Mb" speed varies from about 2 to 7.5 depending on the day and the time of day.
It also takes some time to settle down whilst the engineers adjust the settings at the exchange to cope with the improved speed. Don't expect any spectacular changes for at least 7 - 10 days.
