catgate Posted March 31, 2008 Report Share Posted March 31, 2008 Well you have to admit that it all fills in that time between meals. Quote Link to comment Share on other sites More sharing options...
CurlyWhirly Posted March 31, 2008 Report Share Posted March 31, 2008 I don't know how to do it in windows but with Partition Magic you would have been able to allocate the free space to your C partition do a new backup and I take it the next time Acronis should recognise the larger space, I think.I'm sure you can do it in Disk Management:The option to delete the partition is blanked out (as I only have the one active partition) but it is there. Quote Link to comment Share on other sites More sharing options...
andsome Posted March 31, 2008 Report Share Posted March 31, 2008 The problem there is that that would have still left me with 80GB instead of 160. At least I think so. :D Quote Link to comment Share on other sites More sharing options...
CurlyWhirly Posted March 31, 2008 Report Share Posted March 31, 2008 The problem there is that that would have still left me with 80GB instead of 160. At least I think so. :DIn that case I would suggest you invest in a copy of Partition Magic as that's what it's designed to do, fill unallocated partition space amongst many other uses.Partition Magic is quite old and so I'm not sure if it's obsolete now Quote Link to comment Share on other sites More sharing options...
rong Posted March 31, 2008 Report Share Posted March 31, 2008 If he nips down to the motorcycle museum at the weekend he would be able to pick up a cheap copy. Quote Link to comment Share on other sites More sharing options...
mark2 Posted March 31, 2008 Report Share Posted March 31, 2008 Acronis gives you the option to resize the partition when recovering/restoring, so increase the image's 80gb to use 160gb.Only used the resize function once, after deleting a partition from my HDDPerhaps you've used the clone drive option ? If your system is not yet completely up and running try running the recovery option rather than clone ? Quote Link to comment Share on other sites More sharing options...
Irene Posted March 31, 2008 Author Report Share Posted March 31, 2008 :0 .... I just hope that I am not faced with the problem of restoring to a new hard drive!! Quote Link to comment Share on other sites More sharing options...
AlanHo Posted March 31, 2008 Report Share Posted March 31, 2008 If he nips down to the motorcycle museum at the weekend he would be able to pick up a cheap copy.He would be able to get a genuine Norton............................. :lol: Quote Link to comment Share on other sites More sharing options...
catgate Posted March 31, 2008 Report Share Posted March 31, 2008 If he nips down to the motorcycle museum at the weekend he would be able to pick up a cheap copy.He would be able to get a genuine Norton............................. :lol:A Dominator? Quote Link to comment Share on other sites More sharing options...
Irene Posted March 31, 2008 Author Report Share Posted March 31, 2008 If he nips down to the motorcycle museum at the weekend he would be able to pick up a cheap copy. He would be able to get a genuine Norton............................. :lol: A Dominator? :lol: :lol: Quote Link to comment Share on other sites More sharing options...
rong Posted March 31, 2008 Report Share Posted March 31, 2008 Yes I forgot to put in Computer Fair Quote Link to comment Share on other sites More sharing options...
Gandalph Posted March 31, 2008 Report Share Posted March 31, 2008 Acronis gives you the option to resize the partition when recovering/restoring, so increase the image's 80gb to use 160gb.Only used the resize function once, after deleting a partition from my HDDPerhaps you've used the clone drive option ? If your system is not yet completely up and running try running the recovery option rather than clone ?Quite right on with that one Mark, that's exactly how to do it. Quote Link to comment Share on other sites More sharing options...
andsome Posted April 1, 2008 Report Share Posted April 1, 2008 Many thanks for the Acronis hints. I didn't think that there would be a problem at the time, and just carried on as normal, having already restored the image on several occasions after experimenting with new programs. I hope the occasion won't occur again for a time. No harm done apart from the time lost, and it probably hasn't hurt to have a fresh installation. Funny how fresh installations differ though. On the last drive the installation gave me A for the floppy, NO B, C for the main drive, D for the second drive, E for the DVD drive and F for the DVD burner. This time I have A for the floppy as usual, NO B, C for the main drive as usual, D for the second drive as before, but this time NO E, the DVD drive is F and the DVD burner is G. My plug in USB drive was allocated as G last time, on this occasion it does not show in my computer, and has installed itself in a folder called NEW FOLDER, which I have of course renamed to Plug in drive. :D Quote Link to comment Share on other sites More sharing options...
