LineOFire Posted January 4, 2005 Report Share Posted January 4, 2005 I have to wholeheartedly recommend IZarc, FileZilla, and Crap Cleaner. Very awesome freeware! I'm just glad people are will to make such great programs for free. :clapping: Quote Link to comment Share on other sites More sharing options...
nellie2 Posted January 4, 2005 Author Report Share Posted January 4, 2005 I'd never heard of IZarc before, did you mean this archive utility a freeware utility that supports rar files among others!! Great! Quote Link to comment Share on other sites More sharing options...
scuzzman Posted January 5, 2005 Report Share Posted January 5, 2005 I'd never heard of IZarc before, did you mean this archive utility a freeware utility that supports rar files among others!! Great!Wow - this thing even supports RPM, TAR, GZ, TGZ Quote Link to comment Share on other sites More sharing options...
LineOFire Posted January 5, 2005 Report Share Posted January 5, 2005 IZarc supports practically every archive format out there, even the new 7-Zip. I like it mainly because it is so easy to use and very configurable.No need for WinZip or WinRar anymore. :D Quote Link to comment Share on other sites More sharing options...
scuzzman Posted January 5, 2005 Report Share Posted January 5, 2005 Can it even concatenate split files - such as is used in RAR? Quote Link to comment Share on other sites More sharing options...
mark2 Posted January 11, 2005 Report Share Posted January 11, 2005 UBCD4WINIf windows won't boot, boot windows from CD and fix from there.Not quite freeware, you need XP beforehand, and to do some work yourself.I've found it useful for virus/spyware cleaning.Power DefragmenterPower Defragmenter is based on Sysinternals defragmentation "engine".Basically its just a very advanced GUI for the Sysinternals core application which takes defragmentation process to a whole new level. Very high defragmentation speed, efficiency and ease of use.XP or W2000 only, speedy? yup, defragged approx 3gb on 13gb partition in under a minute.avast! External Control 1.6avast! External Control (AEC) tool was designed to extend avast! Antivirus functionality and security.AEC gives you almost full control over avast! Home Edition or Professional Edition.You can fully disable/enable and Auto-Restart avast!, change update and VRDB generation intervals, tweak many hidden settings and view detailed avast! Antivirus statusExploring this one a little further Quote Link to comment Share on other sites More sharing options...
Boris Posted January 11, 2005 Report Share Posted January 11, 2005 Power DefragmenterPower Defragmenter is based on Sysinternals defragmentation "engine".Basically its just a very advanced GUI for the Sysinternals core application which takes defragmentation process to a whole new level. Very high defragmentation speed, efficiency and ease of use.XP or W2000 only, speedy? yup, defragged approx 3gb on 13gb partition in under a minute.Just tried it myself on a 50% used 25gig partition. That is stonkingly quick performance for a standard defrag !I use Raxco PerfectDisk normally and the speeds are very similar.Raxco's "Smart Placement" facility just gives it the edge over PD - but "it ain't free" so this is well worth a try ! :D Quote Link to comment Share on other sites More sharing options...
doug Posted January 11, 2005 Report Share Posted January 11, 2005 Is this any advance on Diskeeper Lite, which is free? Couldn't make out if this is a freeby. I always prefer to shop there! Quote Link to comment Share on other sites More sharing options...
Boris Posted January 11, 2005 Report Share Posted January 11, 2005 doug,The whole thread is freeware ! Quote Link to comment Share on other sites More sharing options...
doug Posted January 11, 2005 Report Share Posted January 11, 2005 Whoopie, I'll definitely be shopping here again. Quote Link to comment Share on other sites More sharing options...
mark2 Posted January 11, 2005 Report Share Posted January 11, 2005 I like this Power defrag, no installation required, ran the .exe from a 32mb usb drive, defragged 16 gb in less than 5 mins. :D Quote Link to comment Share on other sites More sharing options...
Snec Posted January 11, 2005 Report Share Posted January 11, 2005 Fans of Belarc Advisor and similar progs will love Fresh Diagnose. I reckon it's the best bit of kit of its type within the Freeware arena. http://www.freshdevices.com/freshdiag.html You can investigate every bit of hardware and software in depth with this. It really is good! Quote Link to comment Share on other sites More sharing options...
Zfactor Posted January 14, 2005 Report Share Posted January 14, 2005 TCP DoctorTCP Doctor can drastically help your connection speed w/ dsl/cable. It can be found Here. I also suggest you use their online tweak tester to find out what number you should use, that can be found Here. What you will ultimately be doing is tweaking your TCP settings to speed up your connection speeds (if possible). Anyway, It has been a while since I used it (since you only realy need to tweak once), so check it out on the site.Active Sync ToggleAnother program I absolutely love is the ActiveSync Toggle by Micrologics. It can be found Here. What it does is allows you to turn off the Active Sync process (the one used to sync any Pocket PC handhelds you may use) and turn it on only when you need it. Obviously this is only of use to you if you use ActiveSync, but if you do and you always wanted to be able to shut the thing off when you do not use it, this is the app for you. Quote Link to comment Share on other sites More sharing options...
prctr Posted January 16, 2005 Report Share Posted January 16, 2005 PC Wizard 2004 is free and provides a wealth of information about your machine / Belarc is great to provide software data, so the two work well in conjunction. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted February 8, 2005 Report Share Posted February 8, 2005 Recently installed RegScrubXP and I am delighted with the results! I found dozens and dozens of download locations on the web, but I was curious where it actually came from. It came from here: http://www.lexundesigns.com/LexunFreeware/index.htmThere are a few other interesting freeware tools on that site, such as Lexun Backup Solution, Lexun DrvCareXP, and the Lexun Browser. Note: all require installation of Microsoft's .NET Framework v1.1 Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted March 3, 2005 Report Share Posted March 3, 2005 Does anyone have a good PDF creator/editor freeware? Quote Link to comment Share on other sites More sharing options...
Belatucadrus Posted March 3, 2005 Report Share Posted March 3, 2005 Does anyone have a good PDF creator/editor freeware?cutePDFPrimoPDFOpenofficeWhile all can convert to PDF, I don't know of anything non Adobe that will edit PDFs Quote Link to comment Share on other sites More sharing options...
king-of-no-pants Posted April 14, 2005 Report Share Posted April 14, 2005 This program is technically freeware, so I will plug it here.www.knoppix.comKnoppix is a distro of linux that you download in .iso form and burn to a CD. After burning it, you can run linux on any computer as long as it boots from a CD. It is great for trying out linux or data recovery. It auto detects all network settings and dosen't write a thing to the hard drive. Its a great thing. Quote Link to comment Share on other sites More sharing options...
king-of-no-pants Posted May 9, 2005 Report Share Posted May 9, 2005 More of my favorite freeware:http://www.grisoft.com/doc/71/lng/us/tpl/tpl01http://smb.sygate.com/products/spf_standard.htmhttp://www.shareaza.com/http://www.ccleaner.com/http://www.winamp.com/ Quote Link to comment Share on other sites More sharing options...
Hilkiah Posted July 2, 2005 Report Share Posted July 2, 2005 Does anyone know of a good freeware for writing CD Images to my hard drive? Only .iso would be fine, but the more the merrier! Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted August 5, 2005 Report Share Posted August 5, 2005 Creating ISO images: LC ISO CreatorBurning ISO images: CD Burner XP Pro Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted November 8, 2005 Report Share Posted November 8, 2005 WhoLockMe?Find out which application has the file "in use" and why you are unable to delete it. See link for more info. Quote Link to comment Share on other sites More sharing options...
rshadarack Posted January 8, 2006 Report Share Posted January 8, 2006 adia - gives a wealth of system informationavg - antivirus scanner/removercygwin - unix in windowsEdit pad lite - beats the pants off of notepadewido - trojan scannerfoobar - plays basically all audio formats, including og3foxit reader - pdf readermedia player classic - plays just about every video format, no need to installmyUninstall - an improvment upon windows add/removeslickrun - couldn't live with out this. Hit windows key + q (or any key you want) to activate, then type in the name of the program you wish to run. A few extra features, but that's about it. No more searching through shortcuts and start menus.reverse connect - dc++tiny res meter - monitors processor speed/usage, ram, pagefile, and every thing else you can think oftrayit - running trayit and holding ctrl while clicking minimize on any window will lower it into the taskbarvti - virtual Ti, have a ti-83 or 89 on your computerxplorer2 lite - beats the pants off of windows explorerIf anyone knows of a great hex editor, please let me know Quote Link to comment Share on other sites More sharing options...
r4may Posted January 8, 2006 Report Share Posted January 8, 2006 rshadarack Posted Today, 03:54 If anyone knows of a great hex editor, please let me knowTry Hex Editor at :- http://www.hhdsoftware.com Quote Link to comment Share on other sites More sharing options...
mark2 Posted January 9, 2006 Report Share Posted January 9, 2006 Saverwiz Freeware windows screensaver maker Quote Link to comment Share on other sites More sharing options...
